I have two outdoor antifreeze faucets that are both leaking from the top metal cap. As shown in the pictures. [
I tried tightening it and using teflon tape then tightening it, but none works. I can get access of the other side of the pipe for one faucet, but for other faucet, the other side of the pipe is behind dry wall.
Any suggestion on what less-invasive solutions I should try next?
How can I make sure I get the right valve without bringing this unit to the store?
... think a little .... what else can you take to the store with you? – jsotola Jun 15 '18 at 3:14
