I'm replacing my current lighting with a new fan. The existing light was attached to a dimmer switch, and I'm putting in a conventional switch since a dimmer would damage the fan. I opened up the old switch and inside is a red and two blacks joined together and attached to the switch. The existing light has two cables going to it, each with a black, white, bare copper, and one cable has a red. The red is connected to one side of the light wiring, the whites are bloomed together and to the other side, and the blacks are joined together. Bares are joined and pigtails to the box.
I'm not sure if the excess wiring had to do with the dimmer or what, but the new fan only calls for one supply, neutral, and ground.
Not sure how to proceed. Thanks!
