The washer has corroded but this supply line just goes straight into the wall. There is no shut off valve so I can’t just unscrew and replace it. Any easy fix?
  • 4
    Turn off the main. – bib Jun 5 '18 at 0:20
    You'd probably want to install a shutoff valve while you're at it. – BillDOe Jun 5 '18 at 0:57
    Hello, and welcome to Stack Exchange. If there's no shutoff, why isn't water spouting out of that end? And, if water isn't spouting out of that end, what's the problem? – Daniel Griscom Jun 5 '18 at 2:10
  • I can’t just unscrew ... you already did .... any other silly questions? – jsotola Jun 5 '18 at 2:30
  • I guess I didn’t explain myself clearly. I know how to turn the water off. I’m asking how I change the fixture I’m holding in my hand which is just a tube that goes into the wall. Most toilets have a shut off valve that this piece is connected to so you just screw and unscrew it. Since this tube just goes directly into the wall I was asking how I can replace it. All the videos I’ve seen show a fixture with a shut off valve. – Brian Jun 5 '18 at 21:33
