You can see into my attic a bit there (looking from the outside of the house into the attic), and it's insulation between the rafters. It's a small storage area and I'm tired of getting the itchies and having to worry about bumping into the insulation when moving boxes around. Can I nail up some thin plywood or some plastic sheeting? I figure boxing the air in like that would help with the insulation as well.
I'm no so concerned with the portions down at the very bottom where the attic flooring meets the rafters, but the higher part (where you can crouch and work in) I'd like to stop getting insulation on me.
