So this all happened when someone plugged in a space heater into a bedroom outlet. it caused a breaker to blow and a few outlets to stop working aswell. At first i just thought it was a breaker that had blown so i flipped it back on and power was restored to the room but the outlets were still not functional.
Green Star: Working outlets
Red Star: Non working outlets
Yellow Box: GFI outlets
Purple star: Where the heater was plugged in
Some things ive done to troubleshoot is first check voltages at outlets 2-8 and they are all reading under 120 volts usually around the 4-40 range. i thought it might have been an outlet that had failed internally and stopped working. So i replaced outlets 2-8 and 10 but the same issue persists i tried using a fluke tone generator to see if the space heater caused some degragation in the wire because of the wattage it required but i was able to succesfully trace the tone from 2-8 and from 1-2 and from 10-9 so im not really sure what the issue could be at this point the breaker seems solid, ive replaced all effected outlets, Double checked GFI's and replaced affected ones. Sort of at a loss here.
Note:Ive also firmly pushed all breakers on and off
Something interesting is the outlets are 2 pronged even though the breaker box is grounded
