Any advice on how to go about fixing this bracket? How do I finding out the replacement model/part details for this thing?
1There is stock at the Orange, Blue and Green big box stores. The replacement may not look exactly identical but it will function identically. – Tyson May 28 '18 at 19:31
Take a pencil and trace around the outside of it so you know where to install the new one. Use a small flat screwdriver to pry it off, take the old one to the home center so you can match it. These are available to purchase. You can then attach the new one with small screws and some adhesive.
