I’m painting the outside of my house. Wood siding. I’m using a brush and roller but I remembered I have an hvlp paint sprayer that I think would be pretty convenient to use. I was reading online that I shouldn’t use hvlp for painting a house. But it didn’t say why. Does anybody know?
Here’s the article that says not to do it. http://www.house-painting-info.com/articles/hvlp/#.WwZDaaJlDYU
I could use an airless sprayer but there is a ton of prep work in that because of the over spray and the hvlp is a bit more manageable in the overspray department.
Also I just want to try it out. But not if it won’t apply the paint correctly or something.
Also the house is small. 950 square feet.
    seems like the complaint may be about refilling the reservoir too often ..... hotrodders.com/forum/hvlp-can-i-paint-my-house-140720.html – jsotola May 24 '18 at 4:59
  • I've used an HVLP sprayer to paint the outside of a 2200sqft house. Worked great - no problems at all. The only minor issue was refilling the reservoir regularly. – brhans May 24 '18 at 11:42
  • They're probably concerned with wind. You should be concerned with overspray. You're thinking "less" overspray means "less" masking. Masking doesn't work that way. – Harper - Reinstate Monica May 24 '18 at 12:17
