Should this have come with weights of some sort? enter image description here
  • Is there perhaps a different type of bulb in one of the sockets?
    – Norm
    May 23, 2018 at 17:05
  • Nope, it leans without any bulbs too
    – ctote
    May 23, 2018 at 17:06
    I looks like one of the arms has been removed. That would account for the imbalance and would be extremely hard to compensate for.
    – bib
    May 23, 2018 at 17:46
  • All arms are there; none are bent
    – ctote
    May 23, 2018 at 22:08
  • Is there any way to change angle of the arms? It seems like a hexagon with a missing side, not a pentagon. May 23, 2018 at 22:15
To me it looks like the arms might have been bent/rotated slightly which causes the imbalance.
Try to see if the arms can be bent/rotated at the joint and try playing around with their positions.
It also looks like the chain can slide horizontally within the shackle, possibly you could balance it out a bit there as well.
Alternatively, if the metal is magnetic you could try buying some small magnets and try balancing them out like that.
Looks like all the arms are there, and none are bent.
Looks like the electric wire coming down from the ceiling is interfering with the chain, preventing the chain from hanging freely. The wire and it's insulation may be too stiff, or the wire too short (perhaps due to the side loop used to raise the fixture)
