I bought a house a bit ago and it came with this plugged into one of the walls. I'd like to remove it as I don't know what it does or if I need it and when thunder strikes the thing makes a noise like it's exploding which scares me. Can I remove this without issue and can I cut the cables?
    You'd need to remove the outlet cover and see where those wires go. They should be dead when the thing is unplugged, but who knows. – isherwood May 22 '18 at 21:05
    Did the house have an alarm? – Tyson May 22 '18 at 21:15
    I lived in an apartment once that had an alarm system wired that way. Is there an alarm panel nearby that doesn't work anymore? – mrog May 22 '18 at 21:17
    @mrog Yes, there's an alarm system and panel that I believe aren't active anymore. – Ian Takao Denegri May 22 '18 at 21:31
  • 5
    @IanTakaoDenegri that’s likely the old alarm’s transformer. – Tyson May 22 '18 at 21:32
1 - Figure out what fuse/breaker controls that set of outlets and turn it off. That is always the official advice before removing an outlet cover, but especially important here as you don't know what you will find.
2 - Remove the outlet cover. If the wires go out of the junction box separately from the regular AC power cable then you should be able to simply cut off the wires from the adapter and push the ends of the wires outside the junction box. That way you will not have any loose wires hanging around 120V waiting to get accidentally energized and zap something on the other end.
3 - If you find that the wires from the adapter are exiting the junction box together with the regular AC power cable then do NOT cut the wires (yet). You will need to find the other end and, ideally, remove the entire cable so that there are no loose wires next to regular AC power cables. Alternatively, you could put wire nuts on the ends of the wire after cutting off the adapter.
Whether or not it is allowed by code (I suspect not), I have seen this type of connection many times. It is never a good idea to run low voltage wiring (telephone, alarm, network, security camera, etc.) parallel to (or in the same conduit as) AC line voltage wiring. Most of the time I have just seen the alarm installers cheat a little and the wire exits the box (or even goes around the box behind the cover plate, not actually "through" the box) and it is easy enough to disconnect the wires.
It looks like a telephone transformer. It once powered your landline telephones. If so, if you have no land lines, you don't need the transformer. The removal advice from manassehkatz seems very sensible and safe.
I am assuming you had an alarm system that isn't being used when you moved in the home? That looks like an alarm system plug. It should be safe to remove, but as someone else said make sure you turn the breaker off just to make sure.
New contributor
MorbidGod is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
