I’m looking to finish my basement. I have a 1940’s cape cod with a poured concrete basement. The basement walls have a fairly thick layer of plaster to them, very rough looking. It’s and in good shape. No water issues. I want to treat the plaster like it’s part of the concrete walls and do glue with EPS board. On top of that I’d build my frame/bays for my walls. Roxul batts with no vapor barrier and then dry wall.
Alternatively, I thought I could just frame out the basement on top of the plaster, use no insulation, and then do whatever finish I wanted (drywall, paneling, etc). I don’t get any added insulation but I also won’t break the plaster and I’d get the look I wanted.
Any help or input is appreciated!
  • You have listed several alternatives but it isn't clear what your objectives and priorities are. What input are you looking for? – fixer1234 May 22 '18 at 5:59
  • Can I safely frame walls and/or insulate over plaster on concrete in a basement? Or will I end up with mold/a mess? – Bigfoote May 22 '18 at 11:28
