I'm working on framing a portion of my garage into a laundry room. I had an unopened package of R-13 faced insulation standing upright on the garage floor, when the garage flooded due to heavy rains.
The way the insulation is packed in, every single piece is folded in half, and it was standing upright on the end where all the folds are. I've taken all the pieces out and laid them out to dry as best I could, but there is a 6" wide strip in the center of every piece where the insulation is compacted instead of fluffy.
I'd prefer not to just throw all this out and get new insulation, but I'm not exactly sure how I'm supposed to use this now. I was thinking maybe I could cut away the compacted insulation in the center, leaving the face intact, and replace it with scrap fluffs I may have laying around. Would this work?
Climate-wise, I'm in central Texas. I'm told the hot-cold side of walls is inconsistent enough that it doesn't really matter which side the face is on. My house is old enough that it doesn't have one of those air-tight/water-tight home wrap seals all over it.
Here's a makeshift illustration I threw together to demonstrate.
