We just moved in to a new apartment and spilled some turmeric over the common carpet area in front of our main door. Tried treating the stains with stain remover, bleach and dishwashing liquid and so forth and so on. No luck with anything. Could anyone please suggest how to remove a week old hard turmeric stains on a colored carpet.
  • how is this a home improvement question?
    – jsotola
    Commented May 19, 2018 at 17:01
  • @jsotola - Where do you think this question will fit in the stack exchange communities? Commented May 20, 2018 at 17:13
Tumeric is the most colorful component of curry. Good luck, tumeric can be used as a fabric dye. It doesn't come out of nice Brooks Brothers white shirts.
Good Housekeeping suggests the following for curry stains in carpet:
Carpet
  1. Mix one tablespoon of liquid hand dishwashing detergent and one tablespoon of white vinegar with two cups of warm water.
  2. Using a clean white cloth, sponge the stain with the detergent/vinegar solution. Blot frequently with a dry cloth until the stain disappears.
  3. Sponge with plain water; blot until the liquid is absorbed.
  4. Sponge the stain with rubbing alcohol; blot to remove the stain.
  5. Sponge with water; blot until the liquid is absorbed.
  6. If the stain remains, mix one teaspoon of liquid hand dishwashing detergent and one tablespoon of ammonia with two cups of warm water.
  7. Sponge the stain with the detergent/ammonia solution. Leave it on the stain for at least 30 minutes, blotting every five minutes with a clean white cloth and more solution.
  8. Sponge with cold water and blot dry.
Personally, I would try it in an inconspicuous portion of carpet first in case it makes things worse in some way.
  • Thank you for the tips. Will try them in order and let you know the result. Commented May 20, 2018 at 17:14
