I'm trying to work out how to unwire an existing shaver socket. There are no obvious fasteners to loosen, just these weird red tabs that click backwards and forwards and can be pulled out entirely. Trying these options though doesn't seem to make any difference to the cables, which I'm unable to remove. existing socket
It's pretty hard to Google for this issue. FYI, I'm in the United Kingdom. Any ideas?
Cheers.
    cut the cables off at the plug – jsotola May 19 '18 at 0:53
    What happens if you push the red tabs in? – bib May 19 '18 at 1:17
  • Try twisting and pulling at the same time. And you might help by identifying your region. (Electrical is variable around the world.) – Aloysius Defenestrate May 19 '18 at 3:58
    Looks like push-to-release connectors. So try pushing and removing the wire at same time.... at worst you can cut the wires as next as you can to the box and rewire the new outlet. – DDS May 19 '18 at 9:22
    Turns out they were push to release connectors. Thanks for the assistance guys. – Iain May 19 '18 at 13:08
For over a year, this "unanswered" question has had an answer and acceptance in the comments:
