I have a wood burner with a regular plug, but it said 220v with 50watt. What size breaker do I need?
  • Hello, and welcome to Stack Exchange. First, you should look through the Help section; we aren't a discussion forum. Second, you'll need to provide us with more information; why do you need a "breaker" at all? – Daniel Griscom May 16 '18 at 2:09
  • a 100W lightbulb uses twice that power – jsotola May 16 '18 at 4:43
  • then it will draw 25w at 110v, assuming it's a dumb heater circuit. if it's got "smarts" it might not work at all. – dandavis May 16 '18 at 16:23
Any plug will do, assuming your in a country where 220 is standard.
50watts at 220volts is less than an amp. (To be exact it’s .22 amps.)
