I am replacing vanity and removing wallpaper to paint. I am currently removing the wallpaper. Do I install the new vanity before painting or after?
Hi! You have a couple of unregistered accounts. Please register one of them, then merge them together, which will allow you to edit and comment on any of your posts. Thanks, and welcome to the site!– Niall C. ♦May 13, 2018 at 15:08
1 Answer
Paint first.
You don't have to worry about getting paint on the vanity.
Areas that would be hard with the vanity in place - in my bathroom, small wall sections on each end underneath the vanity since the countertop is wall-to-wall but the vanity is (deliberately) a little shorter - are very easy.
If you ever replace some or all of the vanity, countertop, etc. and the replacement is slightly smaller you won't end up with unfinished areas that then need to get painted.
But overall it is just simpler to paint large sections of walls than dealing with lots of edges.
Look at it this way. If you don't like it after you install the vanity (or seriously ding something up) you can still paint after.– StanwoodMay 11, 2018 at 2:30
