holes are popping up in walls and ceilings of both bedrooms
enter
  • 9
    The first picture looks like an infestation of the Phillips head screw. They're known to make holes in all kinds of surfaces.
    – fixer1234
    Commented May 11, 2018 at 0:54
    @fixer1234 is it the flesh eating screw worm?
    – Kris
    Commented May 11, 2018 at 17:38
    holes are popping up in walls and ceilings .... really? .... looks to me like you are not very observant and you take a long time to notice that screws are sticking out ... that first picture shows a screw that has been painted over, so it has been like that a long time
    – jsotola
    Commented May 11, 2018 at 17:44
  • no this only hole with screw..first day it was hole only
    – wildchild
    Commented May 11, 2018 at 23:40
    then somebody put the screw there and painted over it .... it did not magically appear
    – jsotola
    Commented May 12, 2018 at 0:28
looks like the nails/screws that hold the drywall is popping. It's quite common especially with houses on shifting soils. If they are screws then run another screw next to/above or below then fill with spackel.
