I went to help install a chandelier today and this is the sequence of events:
  • There was no light fixture in pace when I arrive. The previous owners had removed a fixture and my friend, who's lived there for two years, just got around to buying one.
  • At the fixture box, there was a black, white, and ground, all with wire nuts on them.
  • I connected the new fixture. Before I hung it, I put a bulb in and tested it. Everything worked fine.
  • I affixed the new light to the box and tested again. I heard a loud pop at the switch (a dimmer switch). The breaker at the panel had tripped.
  • Thinking it was the dimmer, I purchased a new dimmer and tried again. Another pop and the breaker tripped again.'
-After resetting the breaker, I bypassed the switch completely and the light worked.
  • I then purchased a single pole switch (no dimmer). I installed it and tested the light. It worked.
  • I put the switch back into the wall and tested again. It tripped the breaker.
  • I took the switch back out of the box and tried again. Tripped the breaker again.
From everything that's visible, there are no shorts.
Ideas?
    How old is the wiring you're working with here? Can you post photos? – CactusCake May 9 '18 at 19:25
  • Does the dimmer require a neutral wire? – Harper - Reinstate Monica May 9 '18 at 21:46
  • Does the breaker have a "TEST" button on it?\ – ThreePhaseEel May 9 '18 at 22:31
  • Did you ever get this resolved? If so, please give a check-mark to the answer or write up your own answer explaining what you did to get it fixed and give yourself a check mark. That will help others with this kind of problem know that this has a resolution and is a good place to look for their answer. – FreeMan Aug 16 at 22:31
I would bet you pinched a wire in the light assembly when putting it back. The switch blew as it was the weak link, or this is where I would be looking. If there are no visible arc marks in the switch or light call an electrician and make sure they have a megger available. A megger is a high voltage ohm meter that will make it possible to find pinched wires that may intermittently work.
| improve this answer | |
  • I've been guilty of tightening a mounting screw right into a wire and shorting it. – Platinum Goose Apr 24 '19 at 14:28
