Okay, full disclosure: I know next to nothing about electronics. Just trying out my first little amateur diy project: adding lights to my vanity. So here goes my question.
I just bought 2 little clip-on "ETL-listed" lamps to clamp onto the top of my vanity, but they have rotary switches instead of in-line cord switches so it will be hard to reach up to turn them off easily. I'll need a longer cord for one of them anyway, so I was thinking to kill two birds with one stone and get a power strip/surge protector to use as an on/off switch as well instead of turning off their individual switches. My question: Would that be a bad idea??
Because I know you're not supposed to do that with computers, but I don't know if that applies to lamps too. I'm mainly worried about starting an electrical fire, not so much the cheap lamps. The 2 lamps take only one 60-watt bulb each if that's important (planning to use the SORAA A19 11-watt-usage, 60-watt-equivalent LED bulbs).
Oh and side note, it's a wooden (expensive) vanity- is it still okay to attach lamps if that's the case?? The lamps have rubber-coated clamps, and I'm using LED lights, but I'm slightly worried about it turning into a fire hazard. I have a 30-day return policy on these lamps. Any info/advice is appreciated!! Thanks!!!!
Update 1 (to address questions in comments): It's a bedroom vanity.
Update 2 (to address questions in comments): in TX, USA.
