So this connection sprung a leak sometime over the winter, I need to add tape to it or replace the connector. How can I get the metal loops off? They aren't the kind that has a screw to loosen/tightenenter image description here
9
    It’s crimp on, you just destroy them to remove. You can replace with the screw type.
    – Tyson
    May 8, 2018 at 1:44
  • How do I get them off though?
    – easycheese
    May 8, 2018 at 1:46
    Sometime you can get ahold of the joint with channelocks and twist and they release... other times it’s more painful. Worst case use a dremel tool and cut them off.
    – Tyson
    May 8, 2018 at 1:49
    they are probably one of these .... amazon.com/421376-STAINLESS-STEEL-CRIMP-RING/dp/B003OL6BXW .... cut off the raised tab
    – jsotola
    May 8, 2018 at 1:49
    Sometimes you just cut the pipe, lose an inch, replace the fitting be done with it.
    – Tyson
    May 8, 2018 at 1:58
