The shower head broke off, and there's nothing to grab onto to unscrew it. I plan to replace the shower head, but do I have to replace the hose as well? Or is there a way to get the plastic bit out?
EDIT: I was reluctant to replace the hose because if something went wrong (e.g. a connector broke), I would no longer have a functional shower and would instead have an urgent plumbing problem. So I spent a lot of time trying to find reverse pliers, to no avail. I experimented with using a utility knife (dangerous!) to get the plastic out, but had no success with that either. After living with the problem for about a year (I am lazy, but I've also had bad experiences with DIY plumbing), I finally got the courage to gently try unscrewing the hose. It was easy, and I was able to replace the hose and shower head.
    Unscrew it from what? I can't tell what I'm looking at in that fuzzy shot. – isherwood May 7 '18 at 19:31
    Get a whole new head with hose. – Jim Stewart May 7 '18 at 19:55
    poke the tip of a knife into the end, then spin it around – jsotola May 7 '18 at 20:36
Get a new head and hose, it's the easiest choice.
Anyway you can try to push around from the inside of broken hose with 'reversed' pliers then unscrewing.
