I have some insulated screwdrivers and the packaging says "Protects from electric shock up to 1,000 volts". But it's not like the insulation can conduct electricity at higher voltages, right?
  • if you had a longer handle then "yes", voltages above 1000 would be protected against by the same material.
    – dandavis
    May 7, 2018 at 17:00
4 Answers 4
Wrong.
At some point, any insulation will break down and either begin to conduct or simply flash over.
From Wikipedia:
Electrical breakdown or dielectric breakdown is when current flows through an electrical insulator when the voltage applied across it exceeds the breakdown voltage. This results in the insulator becoming electrically conductive. Electrical breakdown may be a momentary event (as in an electrostatic discharge), or may lead to a continuous arc if protective devices fail to interrupt the current in a power circuit.
Under sufficient electrical stress, electrical breakdown can occur within solids, liquids, gases or vacuum. However, the specific breakdown mechanisms are different for each kind of dielectric medium.
So, respect the rating on your 'insulated' screwdrivers.
To start with, electricity is perfectly capable of going around insulation in an arc, so even if you had a theoretically perfect screwdriver handle, there's a point where electricity would ignore the handle and use the air instead. So the screwdriver maker is forced to make certain assumptions, e.g. that you are clever enough not to let beads of sweat run down it, or use it in the rain.
What's more, any material does indeed have a breakdown voltage. If you kept increasing voltage, eventually the voltage would pass through the insulator anyway. This is why insulation is tested with a megaohmmeter, which measures resistance against hundreds or thousands of volts of test voltage, which it generates for the test.
Here, people often complain that their appliance trips a ground fault detector, yet they measure infinite resistance between hot/neutral and the machine's ground. They are using a common multimeter, which has a test voltage of a couple of volts. Insulation won't break down at those low voltages, hence the megaohmmeter.
Look closely at high voltage lines: their insulation is a series of ceramic "bells". The bell shape is to give the longest possible pathway via both the insulation surface and the air. By stacking bells, they increase the insulation further.
enter image description here src
  • Interesting! Can you elaborate on the bell shaped design / longest path bit? Is that something to do with the skin effect?
    – CactusCake
    May 7, 2018 at 20:02
  • No. It's simply to increase the distance the current have to jump, as the breakdown strength of air is significantly lower than the breakdown voltage of the insulator.
    – vidarlo
    May 8, 2018 at 7:51
    Hmm, but why not just use cylinders then? Rain?
    – CactusCake
    May 8, 2018 at 12:48
At 1000V and above, the "creapage" distance required to prevent tracking across the surface likely exceeds the thickness of the plastic handle.
There is no such thing as a pure insulator; EVERYTHING is a conductor, some things are just better than others depending on the voltage. Such is the fallacy of people thinking they are protected from lightning because they are wearing rubber shoes, or driving in a car with rubber tires. The lightning ALREADY passed through the dielectric strength of a mile of air, 1/2" of rubber is not even significant at that point.
-1
https://www.youtube.com/watch?v=AGXQNLq19FQ&start=290
In that video they test a 1kV rated screwdriver to destruction. It takes a surprisingly high voltage - 100kV - to get a breakdown in the insulation.
But the reason that they're rated to 1kV is that 1kV is the difference between low voltage and high voltage in many jurisdictions. With high voltage, the requirements change drastically. For instance, with low voltage, it only has to be secured against re-connection. With high voltage, it has to be grounded as well. On high voltage one person shall monitor the safety of the system, and not participate in the work.
There's quite a lot of regulations like that, which effectively makes it pretty uninteresting to have hand tools approved for more than 1kV. You don't work in the same ways, it's usually not the same people doing the work, and you need different methods due to different risks. For instance low voltage (<1kV) is only dangerous if you touch a conductor (or are exposed to an arc), whilst high voltage (>1kV) can jump airgaps.
(Those are examples from Norwegian regulation; Europe mostly has variations of it. No idea about USA tho)
  • I have seen 480vac flash over, usually on loads exceeding 75 amps, especially when opened under load.
    May 7, 2018 at 20:41
  • Yes, arcs may happen at any voltage. But you have never seen 480V suddenly jump between points without any previous contact.
    – vidarlo
    May 8, 2018 at 5:23
  • I actually have seen a 800 horse disconnect running a 500 go motor flash over while running not at startup, no idea what caused the flash over dust bridging? Inside the disconnect the lugs were heavily damaged but the conductors were fine so it was not loose connections as many times has been the case with high power industrial failures.
    May 8, 2018 at 20:35
