On our property we have a main house and an 800 sqr foot detached "guest house". To the right of the entrance to the guest house is the electrical service / meter. The wires for the electrical service go into conduit in the concrete slab that is around the door, and off underground to where the power comes down the utility pole on the corner of our property. Right next to the electrical service in the concrete is another piece of conduit that also goes into the concrete. Stuck out of that are cut off, thick electrical wires (The size of electrical service). I would like to know where this conduit goes, does anyone have any ideas/techniques to determine this?
First and foremost I want to clean-up the electrical wires that look kind of scary and out-of-place just sticking out of that conduit. Knowing where the "other end" is should make it easier to pull out the cable since there is barely enough to tug on sticking out now. Second of all, I'm wondering if the conduit goes to the main house (e.g. I'm thinking the guest house was powered from the main house before it had its own service). If it does, I may be able to use this conduit to help run an ethernet line I want to run to the guest house. To do this though, I really need to know where the other end is.
Any ideas?
