The ac keeps on leaking and now there is a bubble formed underneath it. Is there any way to fix this right now?
  • Hello, and welcome to Stack Exchange. Commercial equipment is probably off-topic here, but the make and model of the air conditioner might help. – Daniel Griscom May 5 '18 at 15:34
I have a similar model pump. About once a quarter I need to take the clear basin out and the float and clean all the gunk off of it then it works fine for a few months. Those mini pumps are really finicky. You could also check the outlet to make sure it isn’t clogged.
| improve this answer | |
  • Cleaning will help, I try to avoid using pumps if possible for this reason, in my area it is legal to allow condensate to be drained outside or into the sewer. I find pumps even my own in the past are not taken care of until they have a problem.+ – Ed Beal Jan 22 '19 at 17:51
