I live in the top floor of a wood frame condo with high ceiling. Lately, my downstairs neighbor has been playing loud music with bass in their living room and I can hear the music and feel the bass on the floor. How can I sound proof the room? It is the wall right behind the TV area. Can I hang a rug or curtain on the wall and it will decrease the noise?
Update: will hanging sound panels on the wall work? How about adding brick veneer? With the strata bylaws, I can't alter the wall as it is a part of the building structure but I can decorate it.
    The answer depends a great deal on how much time and money you're willing to invest.
    – Matthew
    Commented May 5, 2018 at 5:06
    Insulating against low frequencies can be tough. The structure will tend to resonate, so any soundproofing you add won't be terribly effective.
    – Hari
    Commented May 5, 2018 at 5:17
    If you can “feel the bass” you have a big problem, that is going to be difficult, if not impossible, to remediate with soundproofing techniques. “Condo” implies ownership of your unit, you may find the answer in your tenants association’s rules. But that angle is off-topic here......
    – Tyson
    Commented May 5, 2018 at 12:16
  • What has your wall in your TV area got to do with you feeling bass in the floor?
    – AndyT
    Commented Aug 14, 2018 at 13:07
  • @AndyT the downstairs neighbor floor layout is similar to mine; their tv/home entertainment setup is in the same area and probably has their speakers right against the wall. When they play loud music or music with bass, I can hear and feel the vibration from the wall as well as from the floor. The apartments below have low ceiling. I can actually feel my floor vibrate when the neighbor jump/run around in their flat. Commented Aug 15, 2018 at 20:36
For base you need lots of solid materials like extra layers of drywall and sound breaks. Carpets and insulation won’t cut it. Softer materials have a little effect on higher frequencies. I built a sound studio with a lot of thought and planning going into sound bleeding into other rooms. We were able to reduce the base but not eliminate it. For a home, there is not much you can do.
