I can buy tree stakes, which are 32mm x 32mm x 1.2m quite easily. However on occasion I need something slightly thicker, say 50mm x 50mm or 75mm x 75mm but of equal or shorter length (<1.2m), and sometimes I need those tree stakes, but shorter. Used for various things around my allotment, driven into the ground with a lump hammer.
The thicker timber is always flat ended, and never spiked. The thinner timber once cut produces a flat ended off cut. Is there a way, other than manually planing the timber into a point, to create this spike. I almost want a very large pencil sharpener.
What I know I don't want is the metal spikes that are used for fencing, as these are costly and pointless for my applications. I have tried to saw the end into a spike, but as I am unable to do this evenly around the edge when driven into the ground its never straight. The timber is too thick to whittle.
