Disclaimer: I have no clue what I'm doing
Over the weekend, I replaced our mulch bed with some rock and a small paver path to our yard:
I laid a thin layer of paver sand under the path, and scrubbed in some sand between the pavers. I sprayed a mist of water a few times over an hour or two to get the sand wet so it would settle. The paver sand doesn't seem to be strong enough though? When I walk on the path, the pavers still shift slightly (enough to make the sand dislodge from the cracks) and I have to refill with more sand, wet, let dry, test again.
Can I use something more rigid? Is there a trick to getting these to stay firmly in place?
