I'm adding a utility sink to our garage. The water heater is a few feet away, so the cold supply line comes out of the adjacent crawl space, heads up the wall to the heater, the hot water leaves and heads back to the crawl space.
Is there any reason I can't use these lines to supply the utility sink? SharkBite connectors to PEX, run along the wall to the sink?
In the attached picture, you can see the supply & output lines to the heater. I'd tee off of them, run PEX behind the HVAC unit to a sink in the corner.
