I realise there is a lot of information out there on LED lights flickering, however I'm struggling to find anything relating to this situation, i.e. GU10 fittings and a regular switch (i.e. not a dimmer). Any help would be greatly appreciated!
We've just moved into a new place and the hall lights fixture takes 3 GU10's and currently only had 1 working halogen in. We've got people coming round tomorrow and wanted a brighter hall so dashed out to get some LED replacements, we did but rather cheap which might be there issue? When all 3 are fitted the light flickers/strobes very strongly the entire time it's on. Replacing one bulb with a halogen mainly fixes this problem so I was thinking this could be due to the LEDs drawing so little current? But I didn't think this should be an issue with GU10s as they work at mains voltage so there shouldn't be any transformer or led driver behind the fitting, and there is no dimmer switch to be causing issues.
Does anybody know why this might be occurring? And would replacing the LEDs with more expensive branded versions help? Or would this just be throwing good money after bad?
Sorry for the long message. Any help greatly appreciated! Thanks.
Edit: Mystery solved, we found a second switch on the circuit we had previously overlooked which was a dimmer, oops. Thank you all for your time and help, and sorry for missing the obvious!
