Anyone know what bit would fit this? I have only seen the 2-prong spanner bits...
These are indeed very rare. And old. Google image search kept showing old radio sets.
After a lengthy search I found one source that should do the trick for you.
Microtech Medium Domed Tri-Wing Wrench Tool Bit (bladehq.com)
    Wow, thank you so much! I also did a lengthy search but came up empty. I also tried unsuccessfully to tap one out with a hammer and a screwdriver but it didn't budge, so you have really saved the day!
    – Rawshark
    Apr 21 '18 at 15:27
  • Soooo it seems the size is way off. I posted another pic in the original post above which shows how tiny the bit is compared to the screw. Any other ideas? i.stack.imgur.com/Ns1AF.jpg At this point I'm also open to the best way to remove them without a bit (drilling, tapping etc.)...? Thanks for any help!
    – Rawshark
    Apr 29 '18 at 14:58
  • Maybe vice-grips?
    – SDsolar
    Apr 29 '18 at 15:56
  • Yeah I tried that but the screw head itself is tapered so there is no way to get purchase...
    – Rawshark
    Apr 29 '18 at 18:34
    No worries - Dremel to the rescue! Cut a slot in the head and used a flathead screwdriver.
    – Rawshark
    Apr 29 '18 at 21:23
Here's what I eventually did to get the screws out:
  • Used a Dremel rotary tool with a metal cutting wheel on it
  • Cut slots across the head of each screw
  • Used a flathead screwdriver to remove them
Hope that helps anyone who might come across this issue in the future.
