I would like to buy a Karcher pressure washer and connect it to a spring water source, not city water.
I didn't measure the throughput yet, but it is less than city water for sure.
I would like to know what is the minimum input flow (liters/h ?) required for a Karcher to work ?
Same question regarding water pressure: what would be the minimum required ? Maybe it is not so relevant since the Karcher will pressurized it ;) Moreover I don't know how to measure water pressure easily.
Any help would be appreciated :) Otherwise I can also try... And see how it goes !
Most consumer pressure washers require a feed at typical municipal pressure and at a flow rate of more than the washer's output. Karcher appears to be an exception.
This video claims that their units can draw the water they need from a static source, like a drum or tank of water or a pool, using a siphon hose. That water isn't under significant pressure (its own weight), but nothing limits the flow in that scenario. If you feed it from a piped source, that source must be sufficient to feed it as fast as it needs it.
I would verify the requirements for the specific model you're considering. The specs should tell you the input requirements, or you can check with Karcher customer service for an official answer.
