like the thread title says: I'm located in Southern NH, allegedly we have 4 seasons although I'm having my doubts about the veracity of that (loonnng winter)
I have an attached 2 car garage with a single door. I wish to insulate it prior to putting up pegboard around the exterior walls. There is soffit ventilation and a ridge vent.
Edit I should mention that the south wall doesn't have a soffit. The west and east walls do. The south wall goes up 8' to the header that parallels the trusses. I plan to put pegboard to the bottom of the header. Question: Will the pegboard suffice for ventilation on that wall? /Edit
Can I use kraft backed fiberglass insulation on the walls and the roof? Will I need a plastic vapor barrier? I do not plan to panel the roof. There is no room above the garage. Could I use lattice to hold the insulation on the roof joists?
thanks in advance for your replies
  • Is there a finish ceiling present? – ThreePhaseEel Apr 18 '18 at 0:13
  • there is not a finish ceiling present. – Raul Apr 18 '18 at 19:40
