To make our walls perfectly flush, our shower wall needs to be floated but the tile we want to use doesn't have a bullnosed version. As such, we were looking at Schluter type edges. If my tile is 1/4" and my set also 1/4", can I just pick up a 1/2" Schluter type edge and have it envelope the tile and the set so it is flush against the wall?
  • What's a "set"? – isherwood Apr 16 '18 at 20:02
  • I thought that meant like thin set mortar. I think I’m out of my depth... – Matt Apr 16 '18 at 20:03
  • No, you're probably fine. Terms vary with region. (And I'm not a tile pro.) – isherwood Apr 16 '18 at 20:04
    Can you please expound on what you mean when you say "walls perfectly flush"? Flush with what? I am experienced with floating walls and floors, and tile, but I need a better idea of why you need to float. Your tile will not be "flush" if you are using a Schluter edge. How bout a pic? – Jimmy Fix-it Apr 17 '18 at 0:14
Your mortar probably won't be 1/4" once you press in the tile. If you're careful it'll be not much thicker than the flange on the edge molding, so you generally purchase an edge with a depth matching your tile's thickness.
| improve this answer | |
