I bought an amazing vintage clock, but have some anxiety about using it, since it's quite old. Some pictures for reference:
GE flip clock GE flip clock bottom expanded vintage GE clock
I would like to re-wire the clock with a newer cord, as the old one has become stiff and worn, and has that old "scary" feel:
GE flip clock wires enter image description here
I was planning to convert the old plug to a UL approved polarized plug. But I'm wondering -- would this conversion actually make the clock any safer? If the clock isn't made to be polarized, then does using a polarized plug change anything about it?
(And this inevitably brings up the sub-questions: Is this clock actually unsafe to operate, or does it just feel unsafe because it's old? Are there different upgrades I could do to the clock to make it more safe?)
    Cool clock, I also wonder how accurate it may be these days – Jon Apr 9 '18 at 4:06
  • polarization without grounding doesn't make much sense; AC is AC. i suppose for a lamp socket it makes sense to keep the smaller connector hot, but the bulb doesn't care... – dandavis Apr 10 '18 at 1:21
  • @dandavis: Polarization can also be important for certain kinds of switched and/or fused loads, to ensure that the current is interrupted on the hot side. – supercat Apr 10 '18 at 14:40
A polarized plug is not inherently safer than a non-polarized plug unless a device requires it. If a device was designed to accept the application of hot and neutral on either terminal, then adding a polarized plug which ensures hot and neutral will always be applied in a single configuration will not make the device safer.
All else being equal about a polarized and non-polarized version of the same plug (age, wear, voltage & current rating, etc.) replacing a functioning non-polarized plug with a polarized plug will not make it safer. However, the opposite (replacing a polarized plug with a non-polarized plug) could make a device unsafe to operate. This is because the device was possibly designed to accept hot and neutral in a single configuration and wiring in a non-polarized plug means that hot and neutral could possibly be applied in a way not intended as part of the device design. That said, the misapplication of hot and neutral terminals to a polarized device is more likely to damage the device than create an unsafe condition as hot and neutral being miswired on the outlet is unfortunately fairly common and is likely to be accounted for in design and testing for foreseeable misuse of more modern UL-listed devices.
The other device-specific questions, I cannot answer. However, if a device is old, it probably old enough to be beyond the age of expected use by its manufacturer and therefore beyond the age at which it has been tested for safe operation (if such lifetime testing was performed or required when the device was manufactured). Using a device beyond the manufacturer's expected/supported lifespan means the device is less likely to be safe and you are right to be concerned. That said, it does not inherently mean it is unsafe either, it is just unlikely that anyone will be able to tell you for a fact that it is safe to operate and you should use at your own discretion or base your decision upon other in-person expert opinion after examination by someone who has experience with your device or similar devices.
I'm looking right at the device. Power goes straight to a magnetic coil and that's it. It doesn't go anywhere else.
Polarizing is useful when one wire is more likely than the other to come in contact with humans. By plain view, that is not the case here.
You could have a third-party rewind that coil if you're that worried about it, but they won't do as good a job as GE.
  • The device also superficially appears to be "double-insulated" in that it has a plastic casing, so any electrical fault internal to the clock would still have to find another fault path out of the device to actually shock anyone. That's one reason not everything has to be grounded or polarized. – Ecnerwal Nov 2 '20 at 23:11
