Mine is a 3-phase German household. Main panel serves the kitchen and a 5 conductor 10 mm^2 with each phase fused 16A (w/ Hager FS) to the secondary panel upstairs. This services 6 rooms, a bath, and attic w/ 10A FS and a 3 phase CDA440D FI (RCD).
How should I make the connection at this secondary panel to another secondary panel servicing the garage? Specifically, what is the right device or connector to bridge two service lines? The panel is a Hager Volta 1P30 3-row, 36 unit. The 5 conductor 10 mm2 input from main panel must feed the 5 conductor 6 mm2 output to the next secondary panel.
The ground/PE/green-yellow should just share the PE bus.
I assume each RCD servicing the upstairs rooms should have its own neutral/null/blue bus. Thus, I need a separate neutral connector.
The 3 phases (L1,L2,L3) could be connected via switch (Hager SH363N), or Hager KC325? Or is another series fuse better (Hager MBN316A)?
