Ideal electrical setup for 26 kVA minimum pull? I know 200 Amps isn't gonna cut it. I have fans and other stuff. Ideally, I'd like to drop them to 240 to maximize power efficiency. I'll be running 21 or 22 15Amp circuits off of the panel. Each unit will have a 1300 Watt pull, 21 or 22 units. I never was a lead electrician, but I did a lot of electrical work back in the day. Any help would be appreciated, much respect to all you other sparkies.
(I am in south us)
Norman
