We are going to be laying hardwood in our entire upper floor. The subfloor between two of the rooms is on a bit of a slope. What's the best way to lay the hardwood over this transition. We are going to be laying it longways through the transition since that is the direction perpendicular to the floor joists. Would it be best to run the hardwood up to the transition and put a board going across at the turning point and make a transition? Fixing the subfloor isn't really an option at this point.
Rough Description: The transition is a doorway that is 36" wide in a hallway. The subfloor on both sides of it is pretty flat. So it'll be fine on both sides of the threshold, but the exact line where they meet will be the issue. In the picture you can see the different subfloor transition between the two rooms. It's made of mortar. There used to be a wall there when the addition was put on the house (in the 70s). It's about 8" wide and the level difference is about 7/16" over that 8"
