I have a table that I want to add another clear-coat layer to (to smooth and level without sanding). It's already stained and sealed, so I want to choose a clear-coat (polyurethane, lacquer, epoxy) that will bind with what was used on it before, but I don't know what was used before.
What's the best way to determine what kind of finish is on this table, so that additional coats will stick properly?
    FYI, the coating on furniture isn't usually called "sealant". "Varnish" or simply the "finish" are more common. – isherwood Apr 2 '18 at 14:13
  • The instructions on most finishes normally call for a scuff sanding before an additional coat, so I don't think you're going to get away without sanding completely. – JPhi1618 Apr 2 '18 at 15:43
