These unusual large screws are from a Balthaup (Germany) dining table,
(My child's "CSI credit card" there for scale :) )
The table's around 12? yrs old.
Any ideas??
+100
You need a pin wrench (or pin spanner).
pin wrench
They come in fixed and adjustable types.
Images and links are illustrative only, not an endorsement of goods or sources.
  • I agree, in the past I have even made one drilling the 2 holes and pressing pins in a piece of bar stock.
    Apr 1, 2018 at 0:05
    @Fattie There are many versions and sources online.
    – bib
    Apr 1, 2018 at 0:25
  • fantastic stuff. I notice the ones that have a number of size pins, are quite expensive. I'll first try exactly the model pictured. Cheers!
    – Fattie
    Apr 1, 2018 at 1:43
  • It turns out this exact model is made for the Balthaup fittings. Excellent!
    – Fattie
    Apr 8, 2018 at 17:06
The Bolts are Spanner Bolts and the tool is generally referred to as a spanner wrench.
TC-Equipment-Variable-Spanner-OTC-526908-7
Spanner Wrench
  • Absolutely fantastic, thanks Ken. "spanner bolts" - "spanner wrench". I saw that very kit for sale, it's a bit expensive. I'm going to try first one of the simple fixed ones which are only a few $$. Thanks - awesome.
    – Fattie
    Apr 1, 2018 at 11:28
  • It would appear these are often used for things like pulleys.
    – Fattie
    Apr 1, 2018 at 11:34
Fantastic stuff - for the hordes of googlers also needing the spanner for this Balthaup table attachments:
indeed the "CRL pin spanner" is perfect. The pin size is exactly correct.
The pitch you can vary, but I was concerned the pin size itself may be wrong. if you have to buy a pin spanner with exchangeable pins, to cover all metric/imperial pin sizes, the only sets I found were 100+ bucks.
Fortunately this CR Laurence model which is only 10-20 bucks is perfect.
Great stuff.
it appears to be known as a "spanner for Top Roller" in some markets.
Thanks, internet
