I live on a fairly small urban lot (~3100sq/ft) and have been having issues with water pooling in my backyard. Recently during a very large rainfall this caused my basement to flood. I'm going to be fixing the cracks in the foundation from the inside, but the flooding is likely the source of the issue.
Because of the restraints of my property I can't really divert the water away anywhere (at least in a way that I can see). I'm honestly thinking about turning the entire grassy area into a rain garden. What else could I possibly do?
enter image description here enter image description here enter image description here
    all that paving isn't helping unless it has a drain that's not shown – Jasen Mar 31 '18 at 3:21
    and do those downspouts go into working drains? – Jasen Mar 31 '18 at 3:24
If your jurisdiction's drainage code permits it, you could install a yard drain in your yard. You would need to slope the lawn so that in a light rain (such that the water can eventually be absorbed by the topsoil) the water does not drain into the drain, but that if enough water collects on the lawn to be a problem, the excess does drain into the drain. You would also need to pipe the drain water to where your roof drain goes to. (This is why you should check with your jurisdiction about its drainage requirements.)
Also, is your topsoil well aerated? Compacted and/or clayey topsoil often does not absorb water well. You might want to consider aerating your lawn, or even replacing the top 8" - 12" of your topsoil with a sandier, more organic mix that is designed for drainage.
