I'm planning to install some plugmold multi-outlet strips hidden under my kitchen cabinets like this:
However, I'm trying to figure out how to hardwire these in a way that passes code. Looking at another similar product from legrand, the instructions are to just drill two holes in the wall and pass Romex wires through. Then the wire-nut connections are made in the outlet strip itself.
I always thought wire nut connections need to be made inside an electrical box-is that right? For my install I'll need the holes to be behind the cabinets, and the romex will run down through a hole in the bottom of the cabinet to the power strip:
Do I need the electrical box in my drawing? Or can I just pass the romex cables through the wall with no box and make the connection in the outlet strip?
Thanks!
