I purchased a electronic cauterization device from China to burn some skin tags. The device's power adapter says 100-240v, so I assumed it's ok to use it in America.
I plugged it into my kitchen outlet, and turned it on, it was turned on briefly, then the outlet just lost power. Then I tried another outlet in the kitchen, same thing happened. I finally wised up and used a surge protector strip, and tried with another working outlet, the device finally was working properly without killing my outlets.
But Now I have two kitchen outlets that doesn't have any power, the rest of the outlets in the kitchen that I didn't plug in the device into still works fine. I checked the breakers and turned them off and on, it didn't help. I test/reset all the GFCI in my house and that didn't help too. Have anyone experienced this before and what could I do to fix this? Thanks
