The flame deflectors in the propane BBQ are rusted to bits. They sit an inch or two above the flames. For making new ones, I know to not use any galvanized or painted sheet metal. What kind of sheet metal would not be a potential health issue?
1Any raw (uncoated) steel or aluminum, really. Replacements are quite inexpensive, though. – isherwood Mar 29 '18 at 17:23
What is the reasoning? – JerryVale Mar 29 '18 at 17:55
1I assumed you knew the reasoning since you mentioned it in your question. You obviously don't want toxic compounds accumulating in your food. – isherwood Mar 29 '18 at 18:05
Yes, by why is any raw steel or aluminum ok? Some alloys must be okay since the originals were some type of metal, probably a ferrous metal given the looks of the rust. – JerryVale Mar 29 '18 at 18:15
The originals were probably run-of-the-mill hot-rolled steel. – isherwood Mar 29 '18 at 18:44
Best would be a cast iron/steel piece, it would last forever and do exactly same as next item.
Second best would be mild carbon steel, what we call black steel where I come from. It rusts like no tomorrow but it is cheap, sturdy and no surprises.
Stainless is a waste of money, heat over time will both make it brittle and leach mystery compounds like chromium into nearby surfaces.
Galvanized is ridiculous, as propane heat will melt the zinc and it will make a puddle.
Best performance is heat resistant high alloy steel with large portions of nickel, molybdenum and others. What we call "kettle steel" in my neck of the woods. But that is hard to work into shape, difficult to weld, heavy as bricks and thus expensive.
I decided to try a large diy stainless steel drip pan fashioned from upcycled BBQ carts, which are everywhere on CL, placed about 1/2" below the grill grates, and about 6" above the flames of the four burners. We've been using tinfoil this way this spring. The SS metal ought to remain cooler than deflectors 1" above the flames. While it doesn't eliminate the risk of fumes, the lower temp ought to reduce the risk. Could also use an old cookie/baking sheet designed for kitchen ovens, but don't have one to spare.
I would use mild steel if making a part , many grills are painted or powder coated prior to using these metals it is a good idea to cure them by running them through a heat cycle prior to using for food consumption. Prior to purchasing a pellet smoker I used propane with mild steel trays I made to hold a little water and wood chips. The trays did last a few years but rusted out so I folded up another set. It was an inexpensive way to distribute the heat and get some smoke flavor out of a propane grill.
Stainless steel would be best; places like Home Depot have an assortment of aftermarket grill parts. Non-magnetic stainless would be better, but magnetic stainless is good ( as in modern auto exhaust systems). Aluminum will disappear fairly fast. Galvanized and painted steel are no health risk.
4Did you really mean to write that galvanized and painted steel are no health risk? – JerryVale Mar 29 '18 at 18:17
I certainly wouldn't want to be breathing or eating burned mystery coatings. – isherwood Mar 29 '18 at 18:43
When galvanized is heated in air , most zinc combines with iron making a stable ( safe) intermetalic compounds. Some zinc evaporates and immediately oxidizes to ZnO ; no problem unless your head is under the grill top - that will cause a few problems. Otherwise zinc oxide is commonly used in skin lotions. Zinc oxide is odd stuff as if you inhale it when it is less than an hour old , you get the "brass founders ague" ( which I can personally assure is gone in 24 hours) . If ZnO is over an hour old it has no affect. – blacksmith37 Aug 8 '19 at 20:50
