I am adding another windows to a sunroom. This will go under the left corner window on the landing (see picture). So of course I will take out the left and right jack studs and cut the middle stud down. I'm wondering if I can get away with cutting only the first left and right king studs to make a stronger window header. For the windows on the right they use two 2x6's of the same length for the header. Can I leave the first 2x6 as it is and then put in a longer one below it to span the cut king studs?
What's different about the left and right? Why can't you do the same thing on the left?– JPhi1618Mar 28, 2018 at 20:25
1 Answer
I wouldn't mess with your kings. The biggest weakness in a wall of windows like this is stiffness. You want as much lumber going full-height as possible.
Also, that's not a header. It doesn't carry any load and merely offers window flange mounting and horizontal stiffness.
Pull the jacks, double the "header" (mullion, really) and toenail it in well, and carry on.
