Got a new Honeywell WiFi thermostat and need to add a common. Currently the 3 common wires per the diagram (BL, BK, GY) are wired to one side of the AC Unit. Is there an issue if I piggy back a common off those wires (add a new wire to the wire nutted bundle).
Thanks!
Go for it man
That's precisely the right move in your case -- that's where the system wiring diagram expects you to tap your C wire at.
