Anyone please tell me what kind hinge (name of the hinge) used in this product ? Name of the product is SNAP JACK from LIVING WITH JACK company.
  • ok RedGrittyBrick, please read this. kickstarter.com/projects/snapjack/snap-jack . in this theyhave mentioned in General material and hardware specification for Snap Jack below the page. now i watched this video watch this video youtube.com/watch?v=qJdz-DM7BbU . @isherwood
    – oryxonfire
    Mar 22, 2018 at 13:52
  • it seems there may be some confusion as to what you are calling a "hinge". The hinge is just the pivot point. The upper part where the two pieces of wood are keyed together are not part of the hinge.
    – agentp
    Mar 22, 2018 at 15:18
Hinges
what kind hinge (name of the hinge) used in this product?
That looks like simple pin (perhaps steel) in a drilled hole and a couple of spacers (perhaps plastic). I don't know of a specific name for this simple arrangement. Nor for the compound hinge formed by the arrangement of three simple hinges to form a folding brace.
Addenda ...
labelled detail of hinge mechanism
In the Snap-Jack furniture
All the fittings, and hinges are stainless steel, and the magnets and keepers are nickel plated, the hinge spacers are plastic
So the hinges are basically exactly as I said above. The magnets are not part of the hinge itself.
Latches
I think [...] a rare earth magnet [...] was used as a hinge
In the Snap-Jack furniture, magnets are not part of the hinge - magnets are used to hold the furniture parts in the fully-closed and fully-open positions. Magnets are also used to help hold the chairs and tables into the wall-mount in the stored position.
Magnetic safety latches
These magnets are not part of the hinges.
Part names
All these parts are available separately from most hardware stores.
  • steel rod
  • steel or plastic washers (maybe spacers too)
  • disk magnets (screw mounted or epoxy into recess)
  • keepers (or use a steel washer and a short wood-screw)
I would use a drill-press with a table rotated 90° to drill the holes for the pins.
10
  • +1 I think they are simply called pin hinges
    – bib
    Mar 22, 2018 at 11:25
  • Thanks for your response RedGrittyBrick. Actually i think this one is a Rare earth magnets (neodymium magnets) which was used a an hinge. what do you think RedGrittyBrick?
    – oryxonfire
    Mar 22, 2018 at 13:18
    @oryxonfire magnets aren't used for load-bearing or stressed parts in furniture hinges. They might be used to lightly hold the strut in the open or closed positions but if so, they are not visible in your photo and are not strictly part of the hinge mechanism itself. Mar 22, 2018 at 13:26
  • ok RedGrittyBrick, please read this. kickstarter.com/projects/snapjack/snap-jackjust . in this theyhave mentioned in General material and hardware specification for Snap Jack below the page. now i watched this video watch this video youtube.com/watch?v=qJdz-DM7BbU
    – oryxonfire
    Mar 22, 2018 at 13:39
  • Precision fitted magnets secure this table in both the open and closed positions. This says to me that the magnets hold position. They don't function as the hinge itself.
    Mar 22, 2018 at 13:41
