I have a bathroom with 2 wall switches, 1 for vanity wall light and 1 for exhaust fan. I want to replace the exhaust fan with a combination light/exhaust fan. The switch that operates the old exhaust fan only operates the light now. The switch has top and bottom screws and both are wired with black wires
Can you post photos of the insides of the switch and fan boxes? – ThreePhaseEel Mar 20 '18 at 22:48
At fan box I added wires blue black black together ..white to white an bare wire to green ground screw? – Rob Mar 20 '18 at 23:29
Is there a question you're trying to ask? Do you want the exhaust fan and light to operate together or separately? (separately will be difficult without running new wire or smart switches) – Stanwood Mar 20 '18 at 23:35
Yes I was wanting to know how to make them both work with the old switch that ran the old exhaust vent but it only works the light now? – Rob Mar 20 '18 at 23:50
The two-way switch in the picture switches a single conductor on and off. I expect you will find that the switched black wire and a neutral white wire lead up to the ceiling fixture. With this setup it's not possible to separately control the ceiling fan and light. But it should be possible to turn them both on and off together. It sounds like that's what you're trying to do.
The exhaust fan should have come with some instructions on how to wire it. We expect to find a neutral white wire, two hot wires (black and blue?) and a grounding wire (green or bare). If the existing wiring to the ceiling is non-metallic cable then you connect black to black/blue, white to white, and green to green/bare or grounding screw. If the existing wires are run as metallic shielded cable then the shield provides grounding and you will need to bond the grounding wire of the fixture to the metal ceiling box.
It sounds like you've attempted the first scenario but the fan is not switching on? Some bathroom exhaust fans are setup to run for a fixed period of time after detecting a certain level of humidity. These can be finicky and may not always turn on when switched on. You might read over the instructions to see if this is what's getting in the way. If it's a simple fan + light then tying the hot wires together should cause them both to turn on. Check your connections and if you can't get it to work try connecting one at a time to debug. It's possible the fan is a dud out of the box.
