This issue I am having is little different than " How do I fix "water hammer" problem asked a few years ago.
1 The problem I am having started a month ago after living in this house for 10 years with no problem.
2 All faucets during shut off create a thud sound.
3 The sound comes from a single location somewhere upstairs either in the wall or attic
4 If I turn off the faucets slowly, I do not get it.
5 Both hot and cold faucets create the sound
6 My incoming city water pressure is 75 psi
7 I tried to shut off all water, drain pipes and restart but it did not work
8 No noise for Toilets or Washing Machines or showers surprisingly. Only all faucets.
9 Putting hammer arresters on every faucet is impractical, right?
Need help. Thanks
  • Mini-Rester Water Hammer Arrestor – ron Sep 18 '19 at 17:10
The solution may be hammer arresters, and it's not that difficult. Or just go back to 'traditional' taps (2-commands 'screw like'). I suggest you to reduce water pressure to about 3bar (about 45 PSI) to preserve piping and reduce hammer effect.
If you have a 'single water entry' to each bathroom, you can install an hammer arrester there, so it protects all the faucets after.
| improve this answer | |
  • I agree with @DDS that water pressure for residential is very high it is normally in the 45PSI range. Arrestors or not your pipes are going to take a beating, add a regulator to the incoming water supply. – user1946891 Jan 16 at 14:18
