There are is gap (approx 0.1cm to 0.4cm) between the interior door frame and wall as shown below. (on the left side is the wall, middle is the gap, right side if the interior wooden door frame)
What are the options available to resolve it and kindly give the pros and cons for each options. Thank you.
    We need more information and a picture would be necessary. There is supposed to be a gap between the door jamb and the rough opening. Shims are used to fix the jamb in the rough opening. This leaves gaps all around between the door jamb the rough opening which are then covered by finish trim called casing. Mar 16, 2018 at 1:45
    What is the material of the adjacent wall?
    – Michael Karas
    Mar 16, 2018 at 2:38
  • @MichaelKaras, should be cement, and oil-based paint painted on it.
    – user275517
    Mar 16, 2018 at 3:49
  • use a cement filler product. The problem you might have is with expansion of the frame, but maybe not.
    – Ken
    Mar 16, 2018 at 8:10
  • @Ken, can I also use normal putty to fill the gap?
    – user275517
    Mar 16, 2018 at 10:09
For small gaps between wooden trim such as doorframes and plastered walls I use a "Flexible gap filler" - available at any DIY store. Spending a few minutes reading the containers carefully and asking store assistants will get you a product you can try.
Description from a randomly selected product
This flexible filler achieves a white crack-free fill between two surfaces where movement can occur. Controlled application is ideal for long linear gaps.
  • For flexible, crack-free filling between two surfaces where movement can occur.
  • Easily controlled application for long linear gaps.
  • For indoor and outdoor use.
Another one
An acrylic filler for draught proofing and filling fine cracks. Can be sanded, overpainted or papered over. Solvent free formulation.
  • Interior or Exterior Use: Interior
  • Application Method: Knife
  • Colour: White
  • Size: 310 ml
  • Type: Ready Mixed Filler
It is often a good idea to rake out the corner first, to remove loose or weak paint. Then sand as necessary before cleaning and filling.
