My old light switch in a bedroom stopped working, and only worked when the switch was pushed and held in the on position.
I purchased another single pole switch. Upon taking the old switch out, I Noticed there were 5 wires...two black, two white, and a ground bare. There are two sets of wires coming into the wall box...one set of wires has the white hot, black, and ground. The other wire has the same three, but no electricity (which I assume turns on my overhead lights in the bedroom.)
The old switch had two side screws used, two push back connectors (where a wire is simply pushed into the hole in the back of the switch), and the ground wire on a screw.
The new switch I wired with the white hot into the push-back, the one black into the other push back, then one white and one black on the side screws, with the ground connected. No lights came on. I tried putting the hot white wire and black wire onto the side screws (swapping the wires between the push back and side screws), and the other white and black wires into the push backs, with no lights working again.
Not sure what this means, but between the white and black wire, I’m getting around 53v. When I put the multimeter on the metal case (near the actual switch) and the black wire, I’m getting 120v. Any help would be appreciated!
