So the machine works fine and even spins fine too until the last bit of the spin cycle when it gets crazy loud (seriously - it's like a jackhammer)!
I uploaded a video - https://youtu.be/IsumwnjEqO8 (starts at second 25) - hoping someone can give me some ideas.
FWIW I did a little research and someone mentioned the counterweight - I don't see any damage to the counterweight and it seems to be attached quite tight too.
  • there could be a bearing issue, but its also possible something got between the drums. Great video. See if you can determine a soft spot turning the drum by hand and listening for an irregular scrape or change in resistance. Take the gasket out and inspect perhaps.
    – noybman
    Commented Mar 10, 2018 at 21:03
  • sounds like and looks like your load ( the clothes inside ) was out of balance and after vibrating for a while something gave way and broke.
    – Alaska Man
    Commented Mar 10, 2018 at 21:07
  • @Alaskaman are you saying it seems like something broke during this video? because this isn't a one-time issue this is what happens during every spin cycle - it's going, going, going, going, and then BAM for 10-20 seconds it's jackhammering! Commented Mar 10, 2018 at 22:35
  • @statichippo It was not clear to me that this was a recurring issue. Have you contacted the manufacturer?
    – Alaska Man
    Commented Mar 10, 2018 at 23:46
  • Same failure on my LG unit in Europe - changed the dampers but no improvement. Suspect it’s the Spider, linking the inner drum to the frame, breaking down. Gave up trying to fix it myself and decided to buy a new machine.
    – No name
    Commented May 5 at 13:13
